Author Topic: loud hiss  (Read 268 times)
KC3EVO
loud hiss
« on: February 20, 2023, 02:27:21 PM »
If anyone knows.... it would be a ham. I recently installed a car stereo amplifier with some aftermarket speakers. They sound great but now I get a loud hiss when the volume is down. Documentation says to check the ground on the amp, which goes to the frame of the car, check the gain on the amplifier which is turned down so far you have to turn the volume all the way up and the output is very low, make sure the RCA's and 4 guage power are opposite sides of the car. It's not an alternator wind, it's a loud hiss! I've been looking for some kind of toroid to wind or clamp on.. Any ideas??
WA2EIO
Re: loud hiss
« Reply #1 on: February 20, 2023, 03:03:51 PM »
If you have to turn the volume up all the way, then maybe the gain is set too low?
WX7Q
Re: loud hiss
« Reply #2 on: February 20, 2023, 06:24:12 PM »
WA2EIO is on the right track.
Googled: "loud hiss car stereo"
https://www.audiocontrol.com/knowledge-base/hiss-coming-thru-speakers-installed-product/
AudioControl always recommends you ground the unit to the battery via the negative terminal.  That option isn’t always available, so the next best way to ground it, is to the chassis of the vehicle.  When you do this, you want to make sure it is grounded to that actually steel chassis, a lot of newer vehicles chassis are aluminum, and if you grounded to aluminum, that can cause problems.  When you ground to the chassis, you also want to make sure there is no paint on the chassis.  Paint can interfere with getting a solid ground connection.
You also want to try to have all of the aftermarket equipment grounded to the same point.
Another good step to confirm if it is indeed a grounding issue, is to take a temp wire and run it to the negative terminal of the battery. Using jumper cables is a good option, since you can just clamp the jumper to the terminal. You would then gather up all of your grounds to that wire. If the hiss goes away, then its a grounding issue and you need to re-configure your grounds.
If we’ve done all of that and you STILL have the hiss, then we would want to check your gain staging.
Meaning, the signal going into the converter may not be high enough, so you need to turn up the gain more, which will then bring up the noise floor more.
HTH...
WX7Q
Jim
KB5ZSM
Re: loud hiss
« Reply #3 on: February 20, 2023, 09:10:39 PM »
Just a note... On some newer vehicles, the Negative post on the battery is not always at the same potential as the car chassis
and connecting the two different potentials may cause damage.
KC3EVO
Re: loud hiss
« Reply #4 on: February 24, 2023, 02:18:57 PM »
Turning the gain up makes the hiss worse.
KC3EVO
Re: loud hiss
« Reply #5 on: February 24, 2023, 02:22:43 PM »
HTH...
WX7Q
Jim
Thanks Jim. I will try to run a temp ground to the - terminal and see if it's a grounding problem. I am using the AudioControl LC7i between the factory amp and the after market amps.
WA3SKN
Re: loud hiss
« Reply #6 on: February 24, 2023, 03:57:21 PM »
What test eqpt is available to you?
-Mike.
