Just got off the phone with Scott. The shipping weight of the xfmr was 320 lbs. It came on a small pallet that weighed
perhaps 10-12 lbs. Then packed on 5 sides with layers and layers of cardboard, then the steel cinch bands. Scott can manhandle and dead lift a 205 lb xfmr.... but not this one. There was no lifting hooks on top, so him and his helper manhandled one corner up onto the bottom of the new power supply box, then the other corner...then manhandled it all on, and slid into it's final place. Then bolted down. It's 4400 vac @ 4 amps CCS / 17.6 kva CCS.
On my own 253 lb Dahl xfmr, it came on a small pallet, with pallet covered in a solid sheet of wood, then a 5 x sided wood box on top of that. I got very lucky..... I had a helluva time getting the 5 x sided box off. The xfmr was exactly 3/16" higher than the bottom of my rack cabinet, so slid it straight across..then bolted down. Mine came with the lifting hooks..which were not used. In some cases, either steel winch cable / chain is used, and a temp steel spreader bar is placed between the cable / chain, and 2 x big folks can either lift, or use an engine hoist, to lift the xfmr...then the rack is slid under the xfmr....then xfmr lowered back down. My 253 lb Dahl is 16" x 16" x 10.75" thick. 5200 vac @ 3 amps CCS. The hypersil pair of cores are good for 20 kva CCS per Dahl himself. The smaller 10 kva CCS Dahl xfmr's are only 127 lbs, and just under 1 cubic foot, abt the same as a 10 kva pole pig (120 lbs out of the oil). My 253 lb dahl is double the weight of the 10 kva dahl, but only 50% more VA. The 441 lb dahl is a solid 30 kva CCS, and is 19" x 19" x 13" thick. I considered it initially, and Dahl talked me out of it, said the 253 lb xmr was ample for my application.
On my 127 lb Dahl 4 H choke, I used a come along, and top lid of new hammond rack temp removed, and a 4" wide channel aluminum piece placed across the top of the rack. Winch cable went across at an angle to lifting hooks on choke. Temp clamps on the basement ceiling joists held the temp angle aluminum pieces pointed straight down. That prevented the new cab from flipping over. Got it in ok, then bolted down.
Stay tuned for part #19, which I will post in a few mins.
