Pages: 1 2 3 4 5 6 [7]   Go Down
Author Topic: 3B7M - Agalega & St. Brandon  (Read 2210 times)
N4UFO
Re: 3B7M - Agalega & St. Brandon
« Reply #90 on: March 08, 2023, 02:12:18 PM »
I had two 10m Qs when I only worked them once. When I went to submit the clublog, I filled in both with the time I worked them the once. It then filled in the exact times from their logs which were one and two minutes off from what I entered. Which means, they logged my one QSO twice and our clocks were off from each other by a minute. No biggie.
BUT, how you got logged on 40m, when you didn't work them... I dunno. I'd put the times of your 30m QSO in there and see if those match. Which would suggest they mis-logged the band, then fixed it and re-logged as the proper band, but didn't go back and delete the incorrectly logged QSOs. It's possible!
K0RS
« Reply #91 on: March 08, 2023, 03:36:13 PM »
They duplicated my 80m QSO as well.
"90% of the people in a pile-up have no idea what's going on.  It's up to you to be in the remaining 10%."  *W9KNI*
KD0PO
« Reply #92 on: March 09, 2023, 04:55:17 AM »
check the time of the QSO and see if it matches one that you made on a different band. It's possible their logging softwear wasn't reading the band data fron the rig.
Ray
« Reply #93 on: March 12, 2023, 10:29:30 AM »
Anybody who requested a direct QSL should have the LoTW matches up by now.
« Reply #94 on: March 12, 2023, 11:21:41 AM »
Got mine this morning.
An exceedingly well-run expedition.  Too bad I didn't hear about it until it was actually on the air.  Worked the h**l out of it anyway.
Pages: 1 2 3 4 5 6 [7]   Go Up
