Mast ideas
Mast design requirements?
Hexbeam (5.5 sq. ft. projected area)
Upper mounting point = 8' above ground
Mast height above the upper mounting point >=10'
Wind survivial, see below
Rotator
Yaesu G-450ADC
Maximum vertical load, 100 kg
Maximum mast diameter, 2.48"
Mast #1
Antenna mounting height 22' above ground
21' x 2" schedule 40 galvanized water pipe
OD = 2.375"
Wall = 0.154"
Tensile strength = 30 kpsi
Freestanding length is 22' - 8' = 14'
The rotator and ground mounting add 1'
Wind survivial = 67 mph
Mast #2
Antenna mounting height 27' above ground
21' x 2" schedule 40 galvanized water pipe + aluminum tubing
OD = 2.375"
Wall = 0.154"
6" x 2.000" x 0.120" wall 6063-T832 aluminum tubing, DX Engineering Aluminum Tubing DXE-AT1313, $79
Freestanding length is 19'
The aluminum tubing telescopes 1' into the top of the steel pipe. Thin aluminum shims make it fit tightly.
Wind survival = 55 mph
Mast #3
DX Engineering Heavy-Duty 4130 Chromoly Steel Masts DXE-ST200CM-22, $1200 plus shipping
(2 in. Mast, Chrome-Moly 4130 Steel Tubing, 100K PSI Min. Yield, 2 in. OD, 0.250 in Wall, 22 ft. Length)
15' free standing
Wind survival, 119 mph
Mast #3
Aluminum Tubing, to be designed
Disclaimer:
I am not a mechanical engineer.
Galvanized water pipe is not recommended for antenna masts yet many of use use them for such.
Plan 'B'.... use sched 80 Galvanized water pipe. BTW, tensile strength does not enter into the equation, only the yield strength.
Another option would be to use 2.875" OD galvanized water pipe, in either sched 40 or sched 80. In sched 80, it's .276" wall thickness.
Bending moment = yield strength X section modulus of the pipe / tubing. Bigger diameter + thinner wall has a lot bigger section modulus vs smaller OD and a thicker wall.
EG: 3.00" CM tubing with a .25" wall has a much bigger section modulus vs a 2.00" OD CM tube, with a .375" wall. IF both have the same yield strength, the 3" tubing wins hands down. But both weigh the same, and cost the same.
Water pipe is typ 35-36 ksi yield strength. CM is typ 105-120 ksi yield strength, but only if heat treated. Un heat treated CM is only 70 ksi yield strength. Aluminum is typ 39/40 ksi yield strength. (6063-T832 / 6061-T6/T8). Galvanized DOM tubing is yet another option..and is typ 75-87 ksi.
As you can see, the stronger alloys are a helluva lot stronger vs 35/36 ksi water pipe. Another option is galvanized fence post material.... which comes in as high as 52 ksi yield strength..and as big as 2.875" OD. KM1H has been using the galvanized 52 ksi fence post for masts for a looong time. They are cost effective.
The issue with aluminum is.... it flexs 3 X as much as steel. (Modulus of elasticity is triple that of steel).
Your issue will be 2 x fold. How much will it bend above..and below the bearing ? It's a fulcrum at that point.
