Regarding mast material - for a long (10 feet or more) unguyed/unsupported, heavily end loaded rotating mast section: Avoid aluminum tubing, regardless of its tensile strength or wall thickness.
The issue is stiffness. Aluminum is many times more flexible than steel and is prone to aeroelastic flutter when the mast is long and top-loaded. Flutter manifests as a gyrating bend in the mast that rotates around it's axis. Essentially, at a certain set of (even modest) wind speeds the mast can whip around in an ever widening circle at the top, potentially destroying itself and/or the antenna. Hard to predict, better to be safe. Happens in some installs and not others.
Steel is a much better choice. And if high tensile strength steel is not used (HTS steel is very stiff and is by far the best choice) and common galvanized water pipe is chosen instead, it can be strengthened/stiffened by insertion of a second, smaller diameter galvanized steel pipe inside the first, using wrappings of duct tape to form "donut" spacers every 12 to 14 inches - and then securing its position using a bolt driven through both pipes. The inner pipe does not even have to be the same length as the outer, but it should at least extend down half of the unguyed/unsupported mast section. This serves not just to strengthen the mast, but as a bending motion damper during strong wind gusts, which is what usually destroys a mast. A "Hammy Hambone" solution, but it does work - up to a point.
Regarding building the mount into a wooden structure - be aware that a long mast "working" back and forth in the wind can and will over time loosen and pull nails and even decking screws free. The structure must be well bolted together at all points, using (many) at least 1/4 inch bolts and broad flat washers on both sides. Even then, the mount will need to be periodically inspected and checked for bolt loosening/wood compression and splitting. A wooden mount has to look very "overbuilt" to safely stand up over time and MUST be periodically inspected.
Some thoughts from actual experience...
Brian - K6BRN
