Home
Help
Search
eHam
eHam Forums
Elmers
Boonton 8210 Modulation meter
« previous
next »
Pages: [
1
Go Down
Author
Topic: Boonton 8210 Modulation meter (Read 182 times)
AD7VO
on:
February 26, 2023, 12:23:48 PM »
Can anyone tell me the proper way to connect a transceiver to the Boonton 8210 meter to measure the modulation?
Do I cable it through an attenuator?
or
Do I put an antenna of the input connector of the 8210 and just pickup the transmitted signal?
or
Some other method?
K7KNX
Re: Boonton 8210 Modulation meter
Reply #1 on:
February 26, 2023, 01:55:32 PM »
NOOOOOO!
The input is sensitive, like about -20dbm sensitive. If you put an HT antenna on it and key the radio into a dummy load close by, it will probably get enough signal to read modulation.
Ken K7KNX
Pages: [
1
Go Up
« previous
next »
eHam
eHam Forums
Elmers
