Author Topic: Harvest HVU-8 opinions  (Read 170 times)
KC1SOZ
« on: February 28, 2023, 02:25:18 PM »
What is the opinion of the community on the Harvest HVU-8 antenna?
WA3SKN
Re: Harvest HVU-8 opinions
« Reply #1 on: February 28, 2023, 02:33:47 PM »
Can't you build a dipole?
What bands are you interested in?
-Mike.
AE0Q
    • AE0Q Amateur Radio
« Reply #2 on: February 28, 2023, 03:04:15 PM »
Looks like 10 hamsticks stuck on two collars and a short mast.  Given that they are about $30 each, at least the price is in line with parts if you made one yourself.  BUT, it will be a pain to adjust all those.
 A wire 40m dipole (or 40/20 fan dipole) would be a lot, LOT cheaper to make if you had room for one, probably work better (since they recommend an antenna tuner anyway), and likely give you a better signal.
Glenn AE0Q
NSGA Edzell 1974-77  CTM2  GM5BKC : NSGA Rota 1972-74   ZB2WZ, SV0WY
https://radioandtravels.blogspot.com/
http://www.qsl.net/ae0q/
« Reply #3 on: February 28, 2023, 05:39:01 PM »
That's an interesting 8' antenna and covers the 80, 40, 20, 15, 10, 6, 2 and the 3/4 meter bands. Due to its length it may perform well on 20 meters and up but not so well on 40 and especially 80 meters.
https://www.dxengineering.com/parts/mld-hvu-8
A somewhat similar antenna (I owned one) is the MFJ-1796 that covers the 40, 20, 15, 10, 6 and 2 meter bands. It should offer better performance because it uses end loading and is rated for 1500 watts PEP rather than 200 watts as the HVU-8 does. The higher power rating indicates much less loading coil loss.
https://www.dxengineering.com/parts/mfj-1796
