Author Topic: Remove Paint From Heat Sinks  (Read 459 times)
K3ZD
« on: March 01, 2023, 01:19:50 PM »
I have a couple of big aluminum heat sinks that someone did a terrible paint job on.  I removed most of it using Aircraft Remover and then blasting it with a pressure washer but not all of it would come off, especially in between the fins and I can't get in there and scrub because the fins are too close together.  I'd like to get it all off but don't know what to do now.
KG4RUL
Re: Remove Paint From Heat Sinks
« Reply #1 on: March 01, 2023, 02:00:02 PM »
Assuming they were painted black, there was no need to remove the paint unless it was so thick it looked like it was applied with a trowel.  Black is a good color to radiate heat.  The only place you need to remove paint is where the device to be cooled contacts the heatsink.
K3UIM
« Reply #2 on: March 01, 2023, 03:10:53 PM »
+1, RUL
K3UIM,
Charlie
Charlie. K3UIM
Where you are: I was!
Where I am: You will be!
So be nice to us old fogies!!
K1KIM
« Reply #3 on: March 01, 2023, 04:22:38 PM »
Easy-Off Oven Cleaner.
And an old toothbrush.
Keep an eye on it. Prob needs  1/2 hour.
« Reply #4 on: March 02, 2023, 07:09:51 AM »
This really depends upon whether the cooling is radiative or convective. However, paint in general increases the thermal resistance of the heatsink so anodizing is preferred for radiative cooling.
KG4RUL
« Reply #5 on: March 02, 2023, 10:11:40 AM »
Agreed but, if it is the paint already on it, black in color and not really thick, taking it off is a lot of effort for marginal gains.
W1RKW
« Reply #6 on: March 02, 2023, 01:39:14 PM »
soak it in a 50/50 mixture of lacquer thinner and MEK, outdoors, then blast with compressed air.
KD0REQ
« Reply #7 on: March 02, 2023, 04:48:06 PM »
can't hurt to try soaking it up with Goof-Off then brushing. unless the black was anodized into the aluminum, then it's dye in closed AlO cells, and it's not coming off. not without sandpaper/grit blasting. and then the surface is rough as a cob. off the shelf black heat sinks are anodized.
WA3SKN
« Reply #8 on: March 03, 2023, 09:03:19 AM »
Aluminum?  You might try a salt water/brine solution before going to the "heavy duty" solutions.  Paint should come off but anodizing will need to be blasted.  Don't lower the mass too much!
-Mike.
