Author Topic: FT1000d or TS690sg...reasons?  (Read 573 times)
W7CXC
« on: March 05, 2023, 03:35:17 PM »
This is for a backup rig. Am getting a headache from arguing with myself. TNX in advance.
W7CXC
Re: FT1000d or TS690sg...reasons?
« Reply #1 on: March 05, 2023, 03:37:31 PM »
Duh....590sg
K6JH
« Reply #2 on: March 05, 2023, 04:59:48 PM »
TS-590SG is still a current model, and well respected at that.
FT-1000D is getting a little old now, and potentially needing repairs like caps or display. Well regarded in it’s day, but…
Really, it comes down to which grabs your heart more.
Jim K6JH
« Reply #3 on: March 05, 2023, 08:05:06 PM »
Do you need 6 meters or not?  If so, 690?  Do you need to actually be able to pick it up and move it?  If so, 690.  Would you like 200 watts?  FT1000
KE0VT
« Reply #4 on: March 05, 2023, 10:43:40 PM »
The TS 590SG is a very fine radio. Easy to operate, only a few menus to set and forget, with out a waterfall. If there is a drawback it is the
built in low power speaker. I added a Phonema speaker, problem solved. You'll never be sorry you bought the Kenwood.
K4MK
« Reply #5 on: March 06, 2023, 04:01:30 AM »
I am not familiar with the Kenwood; it' s probably a fine choice. However, I have been using my 1991 model FT-1000D for 30+ years without a failure. It' s enabled me to achieve # 1 DXCC, as well as using it to enjoy many long ragchews. It is indeed old, but still a good rig. The Kenwood would be a more modern and flexible choice; just kind-of depends on what you prefer.
K7JQ
« Reply #6 on: March 06, 2023, 05:28:20 AM »
For a backup radio, I’d stick with a currently manufactured radio priced under $1.5 K. Why worry about parts or service availability on a long discontinued radio?
Also, I don’t know if you’ve experienced/used a panadapter/waterfall. I would never buy another radio without one built-in. An Icom 7300 or Yaesu’s FTDX-10, FT-10 would be my backup radio choice.
AC7CW
« Reply #7 on: March 06, 2023, 07:10:54 AM »
Duh....590sg
I thought I was going to have to read up on a new model there for a minute....
AE5SB
« Reply #8 on: March 06, 2023, 08:06:05 AM »
so many can't read these days, TS 690 is NOT TS 590
« Reply #9 on: March 06, 2023, 08:09:11 AM »
Well, you asked. In my opinion, neither. When so many cheap new transceivers with so much more capability are readily available.
K6YE
« Reply #10 on: March 06, 2023, 08:14:59 AM »
I echo the other comments. The Kenwood is a newer radio with advanced features. I have had a new FT-1000 (upgraded to 1000d) since 2001. It has never failed. I am replacing it with an Icom IC-7800 that a friend is discarding after acquiring an Elecraft K4D. The 1000D is still in operation and I use it one week every month.
Every radio is subjective, according to the user's wants/desires. In short, the "best" radio is the one YOU like to use. Good luck in your quest.
Semper Fi,
Tommy - K6YE
DX IS and CW RULES
AE0Q
    • AE0Q Amateur Radio
« Reply #11 on: March 06, 2023, 02:28:31 PM »
Duh....590sg
Well a TS-690S was a Kenwood model :-)
https://www.universal-radio.com/catalog/hamhf/ts690s.html
Old, not new, if that had been what he meant, but obviously not...
NSGA Edzell 1974-77  CTM2  GM5BKC : NSGA Rota 1972-74   ZB2WZ, SV0WY
https://radioandtravels.blogspot.com/
http://www.qsl.net/ae0q/
KO4HNB
« Reply #12 on: March 06, 2023, 05:03:58 PM »
Just bought a 590sg and am amazed at the audio. Great receiver, plenty of options for tweaking audio in and out. Versatile software, easy to set up. It lacks a waterfall, but that is a small loss for all the other benefits. (I have a panadapter with another transceiver- nice accessory, but I do not use it often.)
KA2FIR
« Reply #13 on: March 06, 2023, 05:28:23 PM »
SSB/CW just sounds more pleasent to listen to on an analog receiver. If you plan to do contesting/CW you can replace the Yaesu filters with INRAD ones for better selectivity.
« Reply #14 on: March 06, 2023, 08:28:33 PM »
SSB sure does sound nice on a Kenwood TS850 and TS950.  The TS950SDX might have been one of the best analog radios ever built!  850 not too far behind it.
