Author Topic: Antenna paint recommendations?  (Read 461 times)
ONAIR
« on: March 06, 2023, 04:43:43 PM »
Any recommendations for spray paint that will not have an effect on antennas?
K6AER
Re: Antenna paint recommendations?
« Reply #1 on: March 06, 2023, 07:45:41 PM »
Any paint will work as long as there are no metal products in the continents.
WB8PFZ
« Reply #2 on: March 07, 2023, 10:11:55 AM »
Is the antenna metal?
N2SR
« Reply #3 on: March 07, 2023, 01:08:07 PM »
Are you thinking that a glass, ceramic, rubber, or wood antenna would work well?
Elect a clown.  Expect a circus.
ONAIR
« Reply #4 on: March 07, 2023, 02:24:58 PM »
   Fiberglass.  I was also wondering what paint would be OK for a carbon fiber mast?
WA3SKN
« Reply #5 on: March 07, 2023, 02:52:49 PM »
Carbon fiber paint??
C'mon guys... there's a small gauge wire inside.  And paint will affect an antenna... it just varies with frequency.  For what frequency is this antenna for? Does it have to be "stealthy"?  What are you really trying to do?
-Mike.
ONAIR
« Reply #6 on: March 07, 2023, 07:14:11 PM »
-Mike.
  Want to mount a white fiberglass 10 meter whip on a green push up carbon fiber mast.  Want to paint everything black for stealth.  Would also like to use the mast as a 20 meter vertical with the wire taped to it.  Thanks!
K1KIM
« Reply #7 on: March 08, 2023, 07:01:13 AM »
As stated, any non-metallic paint will work. I'd use flat.
ONAIR
« Reply #8 on: March 08, 2023, 05:20:20 PM »
     Thanks!
W1MOW
« Reply #9 on: March 09, 2023, 06:39:11 AM »
We used a Krylon plastic paint when installed a PVC encased Ed Fong Tri-band at my Son's HOA restricted house. Bird site master showed no loss or difference from before we painted.
Gary W1MOW
The fundamental cause of the trouble is that in the modern world the stupid are cocksure while the intelligent are full of doubt - Bertram Russell (1935)
So not much has changed in almost 90 years!
ONAIR
« Reply #10 on: March 09, 2023, 11:29:29 PM »
Gary W1MOW
   Thanks!  Is that the inexpensive spray paint they sell at big box stores?
W1MOW
« Reply #11 on: March 10, 2023, 08:40:16 AM »
Gary W1MOW
Yes, we paid under $5.00 for the can, and matched it to his house color. From the road you just see the tip. We got it at Ace hardware, I noticed that HomeDepot sells the Rustoleum, Lowes sells Krylon Fusion for $7.98 a can.
Gary W1MOW
