9:1 transformer [/u]
A 60' counterpoise for a 80-10M EFHW of 123' seems excessive. Many are using 15'-20' counterpoise with a 49:1 UNUN.
Not the same thing. I've played with both, definitely use far different counterpoises. The 9:1 needs one to balance overall length of what is often a 1/4 wave antenna and an EFHW needs maybe 10% of what is essentially a half wave antenna.
That said, I have a 160m EFHW and one might say it has either no counterpoise (the way the transformer is wired), 1.5-2.0 feet (the metal post the transformer is mounted on) or ~88 feet (buried coax length to a common mode choke) depending on what you consider a counterpoise.
