these have an overheating problem if they are transmitting for too long.
What is "too long" -?
To be fair, adding a fan probably wouldn't hurt. It would be useful to know though under what conditions it will actually make a difference, e.g. prevent the radio from going into thermal limit. Fans add cost and reduce reliability, so it's a tradeoff between that and imposing a duty cycle.
I've added fans to equipment over the years and it doesn't take a lot. Running a 24V fan, or 2 12V fans in series results in sufficient airflow and almost no noise.
Even easier is to drop the power back. 50W out translates to about 50W dissipated, so at 25W out the heat generation is cut in half, but the signal strength goes down only a few dB. Sometimes that can make a difference but not often. You may find at 25W the duty cycle goes up enough that there's no thermal issue at all when operated the way you will use it.
