DISCLAIMER: The past 10 or 12 SPE Amplifiers that came into my shop for catastrophic repairs were already at an unknown shop that "supposedly" supported SPE amplifiers. I do not know "who" or "where" nor do I care but as result it has been noted several extremely bad repairs were performed. I am in NO WAY associated with SPE or these repairs and ONLY able to clean "some" of them up. These previously hacked amplifiers included massive solder issues (Blobs and Strands) , SMT hacks , ripped traces , white wire repairs in impedance crucial areas, 1/2 solder flowed LDMOS IC's and in most cases low heat soldering / flow flaws. Lastly roaming hardware thru out and heatsinks not torqued.
While I will try to repair some of the ones I received , I am no longer supporting SPE. Good luck to the new tech guy, should there be one, I wish him luck
