Author Topic: SPE Amps recently received  (Read 434 times)
N4ATS
« on: March 14, 2023, 10:32:20 AM »
DISCLAIMER: The past 10 or 12 SPE Amplifiers that came into my shop for catastrophic repairs were already at an unknown shop that "supposedly" supported SPE amplifiers. I do not know "who" or "where" nor do I care but as result it has been noted several extremely bad repairs were performed. I am in NO WAY associated with SPE or these repairs and ONLY able to clean "some" of them up. These previously hacked amplifiers included massive solder issues (Blobs and Strands) , SMT hacks , ripped traces , white wire repairs in impedance crucial areas, 1/2 solder flowed LDMOS IC's and in most cases low heat soldering / flow flaws. Lastly roaming hardware thru out and heatsinks not torqued.
While I will try to repair some of the ones I received , I am no longer supporting SPE. Good luck to the new tech guy, should there be one, I wish him luck
« Last Edit: March 14, 2023, 10:40:08 AM by N4ATS »
VR2AX
Re: SPE Amps recently received
« Reply #1 on: March 14, 2023, 11:01:41 AM »
Good thing we hams always keep perfect records and always retain them against all and every possible legal inspection.
ZS5WC
« Reply #2 on: March 15, 2023, 07:11:55 AM »
 :)Wow that is shocking and sad.
SPE makes a good product, its a pity these Back Yard techs give them a bad name.
I repaired my own, was not that easy, but it was done thoroughly and neatly.
Problem is when non solid state amp savvy people pull everything apart in order to find a fault, that could mostly be caused by operational errors.
73!.
KA4WJA
« Reply #3 on: March 15, 2023, 08:47:35 AM »
Bill,
Wow!
Thanks for posting this.  (it's always good to know stuff like this)
While I will try to repair some of the ones I received , I am no longer supporting SPE. Good luck to the new tech guy, should there be one, I wish him luck.
Makes me wonder if he was trained at Ameritron / MFJ?  hi hi  (As their signature seems to be flowing hardware but not flowing solder)
Okay, I'm just kidding Ameritrom/MFJ.  They do make some nice ham kits....that actually look better than the old Heathkits.
John,  KA4WJA
