Author Topic: Stop Vibroplex from slidding around  (Read 347 times)
K7MPZ
« on: March 14, 2023, 07:18:03 PM »
Ok, I guess I am a heavy fisted operator, but the key only has 3 little rubber bumpers underneath, and
it slides left and right on the smooth varnished desk top.  What more can I say?
Dale Fiorillo
Sequim, Wa
K7MPZ
N8RKD
Re: Stop Vibroplex from slidding around
« Reply #1 on: March 14, 2023, 07:24:00 PM »
I use a rectangle of tacky shelf liner under mine.  Seems to help.
W6QW
« Reply #2 on: March 14, 2023, 08:03:10 PM »
Had the same problem with my Vibrokeyer.  Solved the problem by:
1. Replaced the rubber feet as they had hardened over time and became slippery on the bottom.  You can purchase new feet from Vibroplex or a third party.
2. Once you replace the feet, simply put the keyer on top of a PC mouse pad.
AE0Q
    • AE0Q Amateur Radio
« Reply #3 on: March 14, 2023, 08:17:05 PM »
These work great for paddles and a slippery desk :-)
https://www.ebay.com/itm/392734387530
Glenn AE0Q
NSGA Edzell 1974-77  CTM2  GM5BKC : NSGA Rota 1972-74   ZB2WZ, SV0WY
https://radioandtravels.blogspot.com/
http://www.qsl.net/ae0q/
NA6O
« Reply #4 on: March 14, 2023, 08:54:28 PM »
Another miraculous cure is to coat the bottom of each foot with a film of rubber cement. Let it dry. It creates a very high friction layer, lasts a long time, and is easily renewed.
Gary NA6O
AJ9C
« Reply #5 on: March 15, 2023, 05:21:17 AM »
I found that the best way to keep my Vibroplex to stop sliding was to sell it and buy a Begali. (tongue in cheek but yea that's what I did)
AC9O
« Reply #7 on: March 15, 2023, 08:35:59 AM »
K6CPO
« Reply #8 on: March 15, 2023, 11:42:26 AM »
I have an old telegraph sounder and key I play around with from time to time. It has metal feet on the bottom of the board it's mounted to so I put a small piece of rubber tool box drawer liner under it and it doesn't move at all now.
N5CM
« Reply #9 on: March 17, 2023, 07:48:25 PM »
I'll admit to being a bit heavy-fisted as well.  I do a little lead casting every once in a while and have a few lead ingots handy.  I cut some of the tacky shelf liner a bit larger than the foot print of whatever key I'm using and place a small lead ingot on the shelf liner on either side of the key.  That seems to work for me.
N2SR
« Reply #10 on: March 18, 2023, 04:56:19 AM »
Drill a hole in the paddle.  Drill a hole in the desktop where you want the paddle to sit.  Run a bolt from the paddle long enough to put a lock washer and nut on the under side of the desktop.
Problem solved.
Elect a clown.  Expect a circus.
K7JQ
« Reply #11 on: March 18, 2023, 06:48:00 AM »
DX Engineering sells non-slip pads for paddles/bugs. I got one free with the purchase of a new paddle…works well.
WA3SKN
« Reply #12 on: March 18, 2023, 10:26:59 AM »
Add weight.
Add friction.
Through-bolt to desk, use fender washers!
-Mike.
K7MPZ
« Reply #13 on: March 18, 2023, 12:56:00 PM »
Thank you all for the many suggestions, even the tongue in cheek ideas!
Dale Fiorillo
Sequim, Wa
K7MPZ
K7MPZ
« Reply #14 on: March 27, 2023, 02:29:09 PM »
For small items like that I use jar opener grippers like these. They work for lots of uses when you can't "get a grip"!
https://www.amazon.com/LUTER-Grippers-Multi-function-Arthritis-Coasters/dp/B0B49Y68LF/ref=sr_1_5?crid=13E7TQ7XNPF77&keywords=jar+opener+pad&qid=1678894467&sprefix=jar+opener+pad%2Caps%2C108&sr=8-5
OMG- these were miraculous. Thank you for link. And they are thin so the paddle height is not changed.
Dale Fiorillo
Sequim, Wa
K7MPZ
