Got a question on a mag mount antenna.. I’m trying to cut a wire for my Larsen mag mount to the middle of the 2M spectrum. Now, correct me if I’m wrong, but a 1/2 wave 2m doesn’t require a ground plane, correct? Well, reason I’m trying to make one, is my SUV has a glass roof, with a small section of metal at the rear that’s about 8 inches wide and spans the length of the roof, about 5 feet. That’s where my mag mount is to go. Now, to simulate a metal ground plane, a long baking pan was used for the metal, figuring it would approximate the theoretical un-needed ground plane. Well, tried tuning this antenna starting at 41” of whip (bottom of mount to whip is about 1.5”) and cut down in 1/4 intervals. I got down to 37” and still my SWR meter pegs out, and power output of my radio (75w) is showing about 30-40 watts depending of frequency. So I know the meter is telling me SWR is bad off. So can someone tell me why this is occurring? I know not having a true ground plane won’t give me the best SWR, but something’s gotta be up with this. I’ve check for antenna shorts, wiring, etc. it is an NMO mount, and I really don’t have any other options for mounting. Now I do have a miniature 1/4 wave mag mount that does work on the vehicle but is not the best. But it’s SWR is 2.0 and I can live with that for its use, but was trying the 1/2 wave figuring there just wasn’t enough metal on the vehicle. Any suggestions?
