Author Topic: Microsat WX3in1 Plus 2.0 Digipeater Set Up Help Needed  (Read 55 times)
K4GTE
« on: March 22, 2023, 06:59:03 AM »
Recently bought a Microsat WX3in1 Plus 2.0 digipeater. Using a Yaesu FT 2980 radio. Having trouble inputting my coordinates in the Microsat configuration software. When I attempt to write configuration, I receive a "syntax error latitude/longitude" error message. It defaults to the manufacturer's coordinates in Poland. I have formatted my coordinates according to the manual, and every format I could think of, with no success. The unit is working fine, except for showing my location. I have emailed Microsat, with no response. Any help would be greatly appreciated.
KC9BUH
Re: Microsat WX3in1 Plus 2.0 Digipeater Set Up Help Needed
« Reply #1 on: March 23, 2023, 08:07:24 AM »
go to aprs.fi and find the location that you want. on the upper left of your screen you will see your coordinates.
exp:38°32.14' N 86°38.08' W    type your coordinates in microsat  as: 3532.14N and 08638.08W
hope this helps
kc9buh
K4GTE
« Reply #2 on: March 23, 2023, 08:38:26 AM »
hope this helps
kc9buh
That worked !  Thank you , I was missing the zero on longitude.
