Author Topic: EV664 microphone transformer  (Read 103 times)
DANCUARTAS
« on: March 25, 2023, 08:32:47 AM »
Hi everyone!!
I got this 664 from eBay, but is not working, it is in pretty good condition aesthetically speaking, but it doesn't work...
I opened it and it seems that someone replaced the transformer before (wiring color do not match and the heatshrink gave me some clues :P)
I have some ideas in mind, I tried to look up some replacement transformer and didn't find any.
I don't know too much about microphones, but:
1. Can I wire the capsule directly to the XLR and test if it is working fine and discard a bad capsule? is it in any way not recommended?
2. Can I wire an SM57 (4 wires) transformer instead of the original (6 wires)? I will leave this microphone in Lo-Z setting.
3. Anyone with a functioning 664 that tells me if this wiring is ok? any other solution maybe?
Thank you, awesome radio geeks!!!
WA3SKN
Re: EV664 microphone transformer
« Reply #1 on: March 25, 2023, 10:00:51 AM »
https://usermanual.wiki/Electro-Voice/ElectroVoice664AUsersManual539083.384552053.pdf
What impedance are you looking for?  Default is hi Z but is capable of 150 ohms.
What test eqpt do you have available?  What are you planning to use it with?
-Mike.
DANCUARTAS
« Reply #2 on: March 25, 2023, 01:04:50 PM »
-Mike.
Thank you for your answer!
I don't know much about impedance and how it will change the sound of it, but I think that low-Z is more universal than high-Z, am I wrong? I will use it with a USB interface for now
« Last Edit: March 25, 2023, 01:08:35 PM by DANCUARTAS »
DANCUARTAS
« Reply #3 on: March 25, 2023, 01:06:20 PM »
