Author Topic: the test-file 210703_133430 for FT8 per the UserGuide's step 6.3 does work.  (Read 143 times)
KM3K
Hello,
I've posted the below to the wsjt-x forum and attempted fixes, as directed by the several replies, but nothing helped my problem.
So I thought I would try here.
I want to run that sample wav file in hopes it would tell me how to handle the QSO sequence, specifically the "automated QSO" as I just don't understand it.
I've read the directions but hoped the wav would show it in action.
My post to wsjt-x forum....
"I've loaded the test-file 210703_133430 for FT8 per the UserGuide's step 6.3.
I did double-click on the file-name and MediaPlayer did run.
But my screen is empty; not at all like the directions.
The "Wide Graph" also does not look ilke the UserGuide example.
Is there something else I was to do, albeit not mentioned in the UserGuide?
Or what have I done wrong?
For what it may be worth, I had seen decoding taking place.
Then, per the UserGuide, I did stop that, erased the screen and tried the "wave file".
I've done several attempts over two days with the same results
TIA for any assistance."
73 jerry km3k
KF6QEX
Try File , Open, ( or CTRL-O )   navigate to the samples folder and then double-click on the file.
You should see signals being decoded
Not sure why the instructions talk about opening the Log directory - although it may be helpful for finding out when the samples folder is hiding
sdrawkcab daer tseb si txet sihT
KM3K
OK. that worked sort of, so thank-you.
At least, this time I had something other than a blank (all black) wide-graph.
So that's a positive.
I do not see the green marker on the wide-graph but that's ok.
Now to post my next FT8 problem.
73 jerry km3k
