Author Topic: JTSync  (Read 148 times)
JTSync
« on: March 31, 2023, 06:06:00 PM »
Downloaded JTSync, and it works fine for syncing my clock with NTP. But it doesn't track my decodes, it stays blank. Any suggestions?
Re: JTSync
« Reply #1 on: March 31, 2023, 06:31:04 PM »
It works if I click the listen button so the button turns blue.
Re: JTSync
« Reply #2 on: March 31, 2023, 06:37:07 PM »
I get an error when pushing the listen button...
Re: JTSync
« Reply #3 on: March 31, 2023, 06:44:20 PM »
Re: JTSync
« Reply #4 on: March 31, 2023, 08:07:11 PM »
Thanks for the help, I've got it working now. After changing the server and port in JTAlert settings, had to do the same in JTSync setting, plus check the multicask box.
Now if I see a station I need with their clock out of sync, maybe I work them. Checked and I'm still reporting to PSK Reporter after making those changes.
VA3VF
Re: JTSync
« Reply #5 on: Today at 03:20:30 PM »
Yes, it's working now.
The only other thing I'll say is that I think you need to sync to a time server again after your successful contact to return to the actual PC clock time.
JTDX has this feature built in but it does not change the PC time, so after the contact, disengage the built-in sync and you are back to the correct PC time.
