Author Topic: EZNEC Pro/2+ and Pro/4+ v. 7.0.2 now available  (Read 119 times)
AC6LA
« on: April 01, 2023, 12:06:34 AM »
Roy Lewallen has corrected two v. 7.0.1 bugs:
1) The Far Field table (via the "FF Tab" button) did not include columns for relative phase.  In v. 7.0.1 the Far Field table typically had Deg/V dB/H dB/Tot dB columns.  With v. 7.0.2 it now has Deg/V dB/H dB/Tot dB/V Pha/H Pha columns.
If you explicitly do not want to include phase in the table use Special Options FFPhase = Off in the .INI file.
2) When using either the builtin NEC-4.2 engine (NEC-4D, available only with Pro/4+) or an external NEC-4.2 engine (Pro/2+ or Pro/4+), switching between Real/High Accuracy and Real/Extended Accuracy ground would not automatically signal that the engine must be run again to update various calculated data items.  This was only a problem when toggling between those two ground choices.  Switching to any other type of ground (Free Space, Perfect, or Real/MININEC) would signal that an engine rerun is required.  Now fixed.
Pro/2+ users can download EZNEC_Pro2+_702_setup.exe here.
Pro/4+ users can download EZNEC_Pro4+_702_setup.exe here.
It is not necessary to uninstall v. 7.0.1 beforehand; v. 7.0.2 will overwrite it.
Dan, AC6LA
KO4NR
Re: EZNEC Pro/2+ and Pro/4+ v. 7.0.2 now available
« Reply #1 on: April 04, 2023, 09:32:53 AM »
Thank you!!
Bill KO4NR
