Author Topic: Yaesu FT-710 and monitor cables  (Read 149 times)
W1MOW
« on: April 01, 2023, 08:04:30 AM »
Just bought a FT-710 to replace my trustworthy FT-450D, in our RV. I would like to use a small 10" to 13" monitor. They only ones I can find have HDMI or VGA ports. I have been looking on Ebay and Craig's list, with no luck for DVI-D monitors.
I have heard stories that DVI-D to HDMI converter cables have caused problems with the radio. I was wondering if anyone has tried a DVI-D to VGA cable?
Thanks
Gary W1MOW
The fundamental cause of the trouble is that in the modern world the stupid are cocksure while the intelligent are full of doubt - Bertram Russell (1935)
So not much has changed in almost 90 years!
W4NBO
Re: Yaesu FT-710 and monitor cables
« Reply #1 on: April 01, 2023, 09:10:24 AM »
Plenty of new monitors with DVI port on Amazon / Ebay. Search "DVI Monitor"
Chuck
W4NBO
W4NBO
« Reply #2 on: April 01, 2023, 09:17:59 AM »
DVI-D means "Digital" which I would think most any new monitor with a DVI port would support this. I am running an older monitor with DVI port on my 710 that is 800x480. Running it because its more of a square monitor that fits in my shelf. If you bought a monitor with DVI port from Amazon and it did not work for some quirky reason you could always return it.
W1MOW
« Reply #3 on: April 01, 2023, 10:37:48 AM »
Chuck
W4NBO
Chuck,
You're right, there is a bunch on Amazon. I am looking for a 15" or smaller monitor. You have to read the ads very carefully, after the 1st couple they're not DVI. Then the 13" and smaller are a lot of money. I have not recently looked on Ebay, I will this afternoon.
Thank You very much,
Gary W1MOW
W4NBO
« Reply #4 on: April 01, 2023, 04:25:28 PM »
Ah, sorry I missed the part about a smaller monitor. I too was concerned about adapters thus have not used one. Hope you find what you seek. Maybe check out local Goodwill stores etc. 73 Chuck W4NBO
K1FBI
« Reply #5 on: April 01, 2023, 07:01:18 PM »
Hi Gary, I have been using an HDMI DVI Adapter Cable with A.I.S. Signal-Interferece-Protection with my FT-710. I purchased it on Amazon Prime for $8.99 and it has worked flawless since February when I purchased it. I have used it with my 23" Samsung Monitor and my 19 " ONN ($100 Walmart special) monitor.
KabelDirekt Products
They make different lengths. I bought the 6 foot one.
I emailed you a hyperlink
« Last Edit: April 01, 2023, 07:09:27 PM by K1FBI »
