If you have concerns about the timing delay and the possibility of hot-switching, the safest way is to use an external keyer. Connect the keyer output to the Key-In of the Centurion, and run a line from the KEY-OUT on the Centurion to the rig key jack. Thi sway, the amp is always in transmit before the rig puts out any RF.
