The SB-220, especially with the AG6K (and other) mods, is an excellent amplifier; however, remember it's going to be more than 30 years old at minimum (and could be closer to 40 years old) and as such, unless everything's already been replaced, parts will be failing and require replacement simply due to age. Those parts include the filter caps and bleeder resistors, for sure, but can also include the main power transformer which is not an inexpensive item.
Also, the SB-220's tuned input can be set for a match on 10m or 12m, but not both; likewise, it can be set for a match on 15m or 17m, but not both. You might try setting it for a compromise (like midway between the optimum 10 and 12m settings, etc) and just use the pi-net in your TS-830S to make up the difference -- which should work pretty well.
And of course, the SB-220 does not cover the band where the most power is usually needed (160m) due to most of us having insufficient space for a truly effective antenna.
I'd personally opt for something a bit more modern that covers 160m...
WB2WIK/6
