Hello,
I'm looking at a used TH-D7A(g) to get up and running on APRS and am running into a problem. I want to use the HT as a dual mobile/home station but when the supplied power adapter is being used the unit resets when PTT is activated. I've never seen any other HT do this that I've owned (only owned Yaesu before). Basically my question is this:
Can this unit transmit with the wall charger in use?
I know the unit uses more amps than the wall charger can supply during high-power transmit, but it would seem that the attached battery should be enough to handle the load and the wall charger keeps trickle charging. Am I missing something with the Kenwood? Do I need to send this thing back? I would rather use the wall charger than a 12V source if I can.
-- Craig
