Author Topic: Garmin GPS55AVD w/Alinco DR-135TP ??  (Read 4456 times)
KB8FXG
« on: February 15, 2002, 09:03:11 PM »
I have a Garmin GPS55AVD aviation handheld GPS that I have had since circa 1992-93 that was hot stuff for us pilots in its day. (no more Loran! Yea!) Anyway, now I would like to hook it up to an alinco dr-135tp and go mobile aprs. I have 3 problems.
1) I dont have the original power/data cable plug (that came with the mounting bracket) because I never used the mounting bracket... instead using a aftermarket yoke mount with a cigaratte lighter power plug.
2) Assuming I can aquire or make up a cable, the gps manual talks of a NMEA "A" , "B" and shield leads... how would these be wired to the mini-plug on the Alinco? (will damage result if trial and error gets them reversed? or is there a standard?)
3) Interfaces listed for the gps are NMEA 0180,0182,0183 version 1.5: dec 1987) with quite a number of approved sentences and transmission rates (time).... however I have no information on baud rate, parity, etc... IE: will this even work?
Any information or ideas would be helpful.
-Chip KB8FXG
KB8FXG
« Reply #1 on: March 11, 2002, 11:48:25 PM »
I figured it out on my own after much trial and error. If anyone needs help with this setup, email me at:
mycallsign@hotmail.com
(to defeat spam robots.. replace "mycallsign" with my actual callsign.
- KB8FXG
