Author Topic: Viking Adventurer Adventurer  (Read 2962 times)
W6RLF
« on: February 03, 2002, 09:40:31 PM »
I've just purchased a Viking Adventurer.  Don't know if it is an "older" or "newer" version, but it is different than most pictures I've seen:
1.  There is a toggle switch just to the left of the "on/off" switch.  It is clearly original, but there is no label.  I assume it is either a "tune/operate" or "standby" switch.  Anyone know?
2.  The back panel has both a phono plug AND a coax connector.  Since the coax connector has coax cable internally running to it, I assume it is the RF output connection; but the rig came with a antenna coax switch attached to the phono plug.  The phono plug has only a thin wire running to it.
Can anyone help me out?
Paul
W6RLF
