Author Topic: Is this a problem  (Read 4790 times)
W3NRL
Is this a problem
« on: December 15, 2003, 06:02:32 PM »
hi to all i am a new member of army mars aat3lk/t
questio:
my ft 847 has been modified for mars, iam using ft847 with g5rv an fc20 tuner, i noticed that when i key up the output power goes from 100 watts to 50 watts to under 20..  is this a problem compromizing with the mods done to the radio.
KC5FM
Is this a problem
« Reply #1 on: December 16, 2003, 01:10:15 PM »
Do you notice this on all bands or just 60 meters?  If it's the latter, I would suspect that it falls in the same realm as the ICOM thread here, i.e. output design does not accomodate the band.
As a result, I don't operate 60 meters at full power.
Let me know how more I can help.
Lloyd Colston    Mayes County Emergency Management
Pryor, OK  USA    http://www.geocities.com/mccem
   Vigilance is the keystone of preparedness
KC2HTG
Is this a problem
« Reply #2 on: January 19, 2004, 01:45:17 AM »
Hello,
        I am also using a ft 847 with the mars mod which covers 60 meters. Upon reading your question I tested my radio into a dummy load and found that on the assigned 60 meter band my 847 has full output in all modes. What is the SWR being presented to your radio? Perhaps the radio is folding back the power due to a mismatch. Good luck Frank kc2htg
W3NRL
Is this a problem
« Reply #3 on: January 19, 2004, 12:17:48 PM »
I have the same problem, my swr's went way out there and cant seen to get them with in reason to operated, my tuner (fc20) tune the everything, until I key up then the swr's go crazy and the power went =
from full power to almost no power.
as for as the other bands (2m,6,440)(have'nt tried hf - tech here)
w3nrl-nick
KB8NJH
Is this a problem
« Reply #4 on: January 05, 2005, 08:40:45 PM »
 Since the G5RV is not a True resonate antenna and
 operates on harmonics, could that be the problem?
 Easy enough to check...try a dummy load..If you
 have a analyzer check the SWR on the dummy load at
 that freq. first...then compare..kind of sounds like
 a fold back SWR problem...hope this helps/ AFT2KA/WV
