Author Topic: IC-7000 RX range expand mod?  (Read 2159 times)
KG7AMV
« on: October 17, 2009, 04:55:46 PM »
What freq's dose it open for RX?
The Mod...
http://www.ham.dmz.ro/icom/ic-7000-rx-range-expand-mod.php
N9NIP
Re: IC-7000 RX range expand mod?
« Reply #1 on: December 11, 2022, 05:38:55 PM »
For what region version is the modification?  I have version S#01, which is the Japan use version.  The different regional versions have different diode matrix configurations.  Which nation do you reside?
LA9XNA
« Reply #2 on: December 11, 2022, 09:54:11 PM »
Just do the full MARS mode
VR2AX
« Reply #3 on: December 12, 2022, 09:10:57 AM »
I agree. I've heard Icom's 'version' or 'region' system described as a 'Byzantine obfuscation'. I doubt whether anyone in Icom Japan could now provide an answer (except 'if it needs programming send it back to the factory').
LA9XNA
« Reply #4 on: December 12, 2022, 09:58:26 PM »
The bords inside the radio is normaly the same.
If you get a picture showing the diode matrix of the radios sold in your country and just replicate that you will get the same frequency range and features.
If it is a japaneese radio it might give less TX power because they have licens class that is only 50w i beleve.
