Author Topic: RF Choke  (Read 12811 times)
KC5NYO
RF Choke
« on: January 08, 2003, 09:07:21 PM »
Just an FYI on how I fixed my TVI problem here........ I was getting into the TV, which is on cable, on 20-6 meters if running over 75-80 watts. I have a 3-element beam that's fairly low at 28' over the roofline on a small quadpod tower.
Tonight I took approx. 12' of coax, installed the connectors, wound it about 8 turns of 6"-8" diameter, and hooked it up inside the shack here to the antenna lead out. Problem solved, can run full power now on all bands with no interference to the TV. My wife is sooooo happy now!  : )
RF Choke
« Reply #1 on: January 09, 2003, 11:28:35 AM »
Congratulations!
That was an easy one, and a good thing to try.
A dozen ferrite cores slipped over the coax, in lieu of the "RF Choke balun" you made out of coax, probably also would have worked and sometimes is easier, if you happen to have the ferrites laying around.
The advantage of the ferrite cores, as opposed to the coil of coax, is you can get ones that just clamp right over the existing coax, so no real "work" needs to be done -- and, you can slide them up and down the coax line, to see what location is most effective at eliminating the RFI.
Good job, though!
