Author Topic: Tonna F9FT Satellite Yagi Antenna 20899  (Read 2780 times)
9A5YY
« on: August 02, 2005, 01:24:28 PM »
Does anybody have experience with this antenna in satellite operation? If yes, can this antenna be used for local operation on 2m because angle between planes of 2m and 70 cm antennas and ground surface is cca 45 degrees? Does anybody know the reason this antenna is tilted for cca 45 degrees? All experiences with this antenna are welcome!
73 de Neven, 9A5YY
