Home
Help
Search
eHam
eHam Forums
Software Defined Radio
TS-450S Auto Tuner Problem
« previous
next »
Pages: [
1
Go Down
Author
Topic: TS-450S Auto Tuner Problem (Read 5192 times)
KD6WKY
on:
June 21, 2007, 07:05:32 PM »
I am unable to reactivate the auto tuner. I have followed all instructions in the manual with no luck. When I push #4 to tune, nothing happens.
KC2RGU
Reply #1 on:
July 13, 2007, 01:00:52 PM »
I had this problem when I installed a tuner in my 450. Did you clip the diode on the inside of the unit? See the manual for details.
NM9B
Reply #2 on:
August 12, 2007, 04:39:10 AM »
The tuner on the TS-450 will not work if the carrier nob is turned all the way to the left. The carrier nob is between the delay and power nobs.
KE4MOB
Reply #3 on:
August 23, 2007, 08:34:47 AM »
When was the last time you changed the memory battery? Sometimes they leak...and the trace for the autotuner is directly below the battery, meaning it gets destroyed in the process....
Pages: [
1
Go Up
« previous
next »
eHam
eHam Forums
