I have an M-Squared 6M7 (7-el 6M yagi - approx 28' boom) mounted approximately 2 1/2 feet below the bottom of two stacked M-Squared 5 wavelength yagi's. The 6M7 is at 82 feet above ground on a Rohn 25G tower. The mast protrudes about 17 1/2 feet from the top of the tower, and the 6M7 is mounted just above the top thrust bearing.
I have observed a noticeable decrease in performance of the 6M beam since I moved it to the new tower configuration. Previously, it was on another tower at about 90 feet elevation, and about 10 feet above a 5-el Hy-Gain 20 meter monobander. The major difference between these situations is that the 6M beam is very close to the long boom 2M beam. I 'feel' that it just doesn't get out like it used to when it was mounted much further away from a large antenna. This is only a feeling, not confirmed by A-B comparison testing. I have run SWR curves on the 6M7 in its present configuration with an MFJ-259B, and I find it has many peaks and valleys in the 50-54 Mhz range, although its pretty flat around 50.1-50.2 Mhz.
I can't tell any difference in the performance of the 2M stack with the 6M beam in close proximity to the bottom 2M yagi. I had the 2M system up for a few months before putting the 6M beam up, and didn't observe any 2M performance changes after the 6M beam was in position. The 2M stack has a vertical separation of 14' 3".
I would be interested in hearing from others that may have close mounted 6M/2M yagi combinations.
Jan, K5MA
West Falmouth, MA
