I'll take another look at my models in EZNec and see what I did. I do know that the antenna is performing well on 80 - 10M, but especially 40 and 30M, which is exactly what I wanted. I'm even snagging a few new band fills on 160M, where the antenna should be a "cloud warmer". Of course in the last few days the A and K have "calmed down", the SFI is up, and there are a number of dx-peditions on the low bands that are very strong. Coincidence? Probably.
A dx-pedition was a solid S9 here on 80M for almost 3 hours the other night - from 1 hour before sunset until just about 9 PM local time. I've never seen that before on 80M, and I earned DXCC on 80M earlier this year. African DX on 80M used to be a painful struggle for my little pistol setup, but I believe conditions were just out of the ordinary for 80M the other night. One of those super path openings.
I didn't seem to have the problem of close in stations being overly loud as compared to the DX - which can be a real problem with a lowband dipole or doublet that is not high enough (i.e 1/2 wl or more).
Only a few local stations in the massive pileup required that I switch in a narrow CW filter.
It does seem to be a "quieter" antenna than my single element horizontal doublet and short hatted vertical dipoles. Not quite as quiet as a loop (I've used K9AY loops before), but more like a loop than a dipole. Its a really neat antenna that takes up the same area as a G5RV . . . . and worth checking out.
I'll report back at the end of the DX season - because I believe you really need many months and need to go through almost a years cycle to get the "feel" for how an antenna performs. I use EZNec to make a decision on which antenna is worth trying, then its on the air experience that counts.
I once bought a really great commercial antenna after a fellow tried it for less than a week and pronounced it a dud. That week was one plaqued with solar flares and high angle noise. Patience is a virtue - hi hi.
