SteppIR says that their steppir motors are very precise, but my brother, who is a mechanical engineer told me to use the calibrate function every now and then - just to make sure.
I have been using mine for about 2 months now, and haven't found any deviation in measured SWR - using the Orion's built in SWR (LCD) metering function.
So, at least for the last 2 months, the BigIR's Steppir motor seems very accurate. It would be very easy to replace the BigIR's motor if it ever did die - since it is 6" above ground. I did avoid the SteppIR yagi when I had 5 acres and a tower - mainly because of the weight and wind load on my Force-12 LPT-1252 tower (which couldn't handle that kind of load).
And I did go with the BigIR to eliminate unecessary devices inline. And I do agree - my SWR is certainly "low enough". With 64 radials, I have been working EU and AF at night, and AS in the morning - so it certainly seems to be at least as efficient as when I had an MA8040V with 64 radials at the old QTH.
Hmmm - I should look up a forum regarding the SteppIR antennas - it would be interesting to see what people think of their antennas and the motors.
Rich
