How much is a dB or two worth in the real ham world?>
Nothing at all really.
<<Actually it's a significant amount if you compare contest scores between high power, low power and QRP classes. 10db usually results in a huge difference and a tenth that is still significant.>>
Ten dB is a lot, but 1 dB is not. No one will really know about 1dB, in a contest or not.
<<Did some research on that question years ago and concluded a single dB added something like 10% to ones CQWW score. Tried to adjust for the fact that QRO stations tend to have better antennas than low power stations.>>
That is a seriously flawed study and conclusion as anyone who understands such studies would understand.
We cannot extrapolate and sort a difference of one dB in transmitter power when the antennas are different, the feedlines are different, the equipment is different, the operators are different, the locations are different, and so on.
I can tell you first hand we can change power here 3 dB and not see any detectable change in QSO rate. The only change is when working staions that marginally hear us, either from heavy QRM or because we are weak. I've looked at logs when we had to use a backup amp and the rate is unchanged.
As for the 5/8th wave, I would never use one. I have a 5/8th wave vertical on 160 meters. In blind A-B tests it is insignificantly different than a 1/4 wave at distance more than 1000 miles. From maybe 250 to 1000 miles it is a few dB WEAKER, and right in close it is a few dB better.
160 is actually a band where the better earth conductivity makes a 5/8th wave have a chance at being better.
Now you might see a change on 20 and higher from the antenna clearing ground clutter better, but that's something you would have to determine with an A-B test. My experience in Ohio was a 1/4 wave antenna at 150 feet AGL was better than a 5/8th wave on 20 meters.
What was I doing? I had a 5 element 20 at 140-150 feet. When I would work Europeans the W4's and W2's would come on for schedules and just start talking. So I ran some tests with Europeans to find a good antenna, and concluded a 5/8th was not worth the wind problems. Compared to the Yagi either was equal.
To stop the W2's from working the W4's in schedules while I was using a frequency, I would transmit on the vertical and only use the Yagi for receiving.
I was about 8-9 dB weaker on the vertical, but I worked just as many Europeans as I could when I used the Yagi and the W4's never came on and bothered me after that.
Seriously, who cares if someone is 20 over nine or 30 over nine? If I was only S5 it would have mattered a little more, but not when signals were good.
Don't get sucked into that 1dB=10% more QSO's stuff. The study is so seriously flawed it is meaningless. If they wanted to do a good study they would have had to use one station and one operator and varied the power every few minutes and looked at the rate.
Contesters go way overboard with signal level, when what really makes a big difference is an accumation of many things....90% of which is location, receiving, and the operator.
73 Tom
