Author Topic: PowerSDR and CW skimmer CAT interfacing problem - "Radio is not responding"  (Read 14831 times)
AG1LE
    • Ham Radio Blog by AG1LE
I have Flex3000 and I am running PowerSDR v2.2.3 and CW skimmer 1.71. I have Eterlogic Virtual Serial Ports Emulator 0.938.4.846. (VSPE)
I have a problem with CW Skimmer CAT control. The bottom left corner radio icon is red and when you hover mouse cursor on the icon you get message "Radio is not responding".
I have tried many different configurations and done quite a lot of Google searching to find a solution without luck. Based on VSPE monitoring I can see that serial communication is working, as messages get sent and response comes back.
Looking at VSPE info screen on COM5 <=> COM15 pair I can see that PowerSDR is using COM15 (as configured) and CW skimmer is using COM5 (Omnirig.exe as configured).
CW Skimmer sends command "AI0;" (in hex 41 49 30 3B ) and PowerSDR responds with "?;" (in hex 3F 3B).
If I turn on "Allow Kenwood AI command" flag on PowerSDR CAT control panel, this response message "?;" does not appear. Using the TEST button on PowerSDR CAT control panel I get the same response behavior if I manually enter the "AI0;" command.
I have tested different combinations on CW Skimmer / CAT interface / Omni-rig settings (rig types PowerSDR / Kenwood / TS-2000 / TS-480) and PowerSDR CAT settings (ID as PowerSDR / TS-2000/TS-480) as well as changing speed (4800/9600/57600), RTS/DTS settings etc. combinations.
I have tried also DDUtil and few other software packages and I am pretty convinced that problem is not in COM port to COM port communication but this is some other higher level CAT protocol configuration issue. I have also tested the exact configurations in the Flex Support pages without luck. I am stuck with this problem.
Has anybody got CW Skimmer and PowerSDR talking to each other via CAT interface?  Any suggestions how to debug this problem further?
« Last Edit: February 18, 2012, 01:13:41 PM by AG1LE »
K0OD
Any help here, the Flex Radio Wiki, which is mostly about using non-Flex products with Flex radios?
http://flexradiowiki.com/frsradoiowiki/index.php?title=Main_Page
I see lots of discussion of CW Skimmer on the Flexradio and Flexedge groups
http://www.mail-archive.com/flexradio@flex-radio.biz/
http://www.mail-archive.com/flexedge@flex-radio.biz/
WD4ELG
AG1E, feel free to contact me off board....happy to help you in real time if possible.  I have same setup as you do, and I got it working after banging my head against the wall.  It's pretty easy and makes sense once I had it set up.
Mark Lunday
WD4ELG
DH2ID
Mark Lunday
WD4ELG
Mark, could you please tell me how you did get CW skimmer to interface with PowerSDR?
I have a Flex-3000 running and CW skimmer decodes, but no radio connection :-(.
I think it is a CAT problem, because my VSPE program tells me that PowerSDR is not
responding to OmniRig signals.
You can also mail to dh2id@darc.de.
Vy 73, Alex DH2ID
WD4ELG
Alex,
I will email you offboard and send you a screen shot of my configuration
Mark
