Author Topic: High volatege mains transformer questions  (Read 18465 times)
2E0ILY
RE: High volatege mains transformer questions
« Reply #15 on: October 02, 2012, 11:09:40 AM »
OK, thanks for that. It's sat running in correctly phased parallel configuration at the moment. Via a voltage divider of 5 megohm my basic AC voltmeter is giving 0.072 to 0.073 volts, which I read as circa 3600V AC. It draws minimal primary current and seems happy enough with no load. That;s with it fed with 230 volts AC 50 Hz.
Peter G3RZP: Thanks for the reply. I often run a serious single phase TIG welder off the supply here, and it draws about 45 Amps. I haven't measured the sag, but the supply doesn't seem to sag dramatically. I think I caused the demise of a very old pole transformer when we moved in, and it was replaced by a much bigger, brand new one.  We are no more than 250 meters from it. I did enquire as to havine 3 phase put in but the cost was prohibitive as there was a road in the way :(  To be honest I have no intention of running it near full capability, but it's a joint venture with a guy convalescing in the UK who is actually American, and he may well take it back with him after he recovers from his bike accident. He tends to like things big fast and powerful :)  The thing I don't quite get is people seem to be suggesting a centre tap and full wave rectifier is the way to go, but I seem to be reading that if the transformer works happily with the two secondary windings in parallel, with a full wave bridge rectifier, it makes more efficient use of the mains cycle? Thanks for your input, much appreciated.
Best regards, Chris Wilson.
« Reply #16 on: October 02, 2012, 12:25:59 PM »
The AC power source cannot tell the difference between the two configurations. They are identical from the view point of the AC source.
« Reply #17 on: October 03, 2012, 04:02:27 AM »
As WX7G says, as far as the AC source is concerned, it makes no difference. But as a bi-phase full wave, you save on the number of rectifiers. It would be worth measuring the current flowing in the lead between the two windings: unless it is zero, bi-phase full wave is better from a balance viewpoint.
That sort of measurement does require, from a safety viewpoint,  a lot of care, though.
2E0ILY
« Reply #18 on: October 05, 2012, 05:46:38 AM »
Thanks for all your patient help, I now have this up and running on the test bench and all seems good so far! Much appreciated, have a good weekend. Going to get it in a safe lockable cabinet now.
http://www.gatesgarth.com/volts.jpg
