Triode Amplifier Bias Boards
by Tony King, W4ZT (SK, Feb. 2009)
http://bias.gs35b.comW4ZT Amplifier Bias Board Documentation
http://bias.gs35b.com/docs/index.htmlOn the home brew just built to the W4ZT schematic it has R5 at 100 Ohms and R2 at 680 Ohms. Ian White has R5 at 10K Ohms and R2 at 1K ohms. Substituting those values and it works fine with no sudden change at the end of the potentiometer low resistance end of the track. Happy as I am to have it working as expected I would like to learn from this, can someone say why it might not have worked as expected before please?
Chris -
Tony had 3 different versions of this Triode Bias board in 2006.
You can tell difference by numbers (design date) etched on foil side of his assembled PC boards.
http://bias.gs35b.com/docs/index.htmlI provided the links (above) from the GS35b / W4ZT web pages maintained by
Tony's good friend, Ron Wilson, K4POZ (Marietta, GA).
http://w4zt.comGI-7b sockets still provided by Ron, K4POZ.
http://gi7b.com/gi7b.htmlTony stated the following, about the last design of the W4ZT Triode Bias Board (060923 etched on foil).
http://bias.gs35b.comThis board is built using the TL431 Voltage reference chip and the TIP147 PNP power darlington transistor.
This circuit is right from the data sheet on the TL431 and is basically the same circuit used by Ian White, GM3SEK and Paul Hewitt, WD7S on their Triode Control Boards.
I built this board primarily as a retrofit for amps that already have a Zener diode in them or for the builder that isn't interested in a full blown control board. --Tony, W4ZT (2006)R1 (10K pot) is in series with R5 .... permitting field adjustment of bias, as required for retrokits in older HF tube amplifiers.
http://bias.gs35b.com/docs/060210a.htmlThe 10K potentiometer, R1, provides a bias adjustment range of approximately 3.5 to 39 volts. For initial installation the potentiometer should be set for maximum bias to insure you start your adjustment at the lowest plate current. Fuse the circuit just above the maximum expected plate current.
