Author Topic: WSJT-X v1.1 r3496 and virtual serial port emulator issue.  (Read 7095 times)
2E0ILY
« on: January 16, 2014, 07:01:32 AM »
 I am using VSPE (Virtual Serial
Port Emulator) and WSJT-X v1.1 r3496  is having none of it. I can get it to poll
the rig frequency of my Kenwood TS-590S correctly only if I disable VSPE and set the 590 to
use the "real" serial port, COM1 and set JT-65 to do the same.
If I use VSPE to split COM1 to COM9 and set JT-65 to use COM9 it won't
get the rig frequency and disables CAT control.
A question. Is anyone using VSPE successfully with JT-65?
Thanks!
Best regards, Chris Wilson.
