Kenwood TS590S and Wellbrook 1530PE.
The Kenwood is really ok after removal of the BC-traps(see Service Manual), which otherwise destroys performance on 11 and 15 MHz.
I also have an Icom R70 which i bought as my first SW radio 30 years ago, and it is a joy to listen to due to being all analogue.
My Sangean ATS-909X is not used much due to bad QC.
It is mostly DEAF on SW and its BFOs are about 150 Hz off frequency, quite an achievement at 450KHz, about 300 PPM! I most likely will never buy Sangean again...
I have the SM, but opening and adjusting the radio without taking Everything apart (including the fragile flat cable) is a challenge due to its construction.
