Author Topic: Delhi/TACO Model DMX-68 64 Foot Tower used?  (Read 13421 times)
KD0VE
« on: July 16, 2014, 01:44:38 PM »
Got an opportunity for a  DMX-68 64' tower local used purchase but haven't been able to find any reviews on same.
Spec says 3 sq. ft. wind load which seems like anything except a vertical would be too much.  Is that correct?
any other comments or advice welcome.
KD0ZGW
W6MK
RE: Delhi/TACO Model DMX-68 64 Foot Tower used?
« Reply #1 on: July 16, 2014, 02:06:45 PM »
Go to the taco communications web site and you'll get all the specs, installation instructions, etc.
Sounds like a very lightweight TV-antenna type "tower" more like a mast.
VE1IDX
« Reply #2 on: July 17, 2014, 04:04:02 PM »
I used to have a regular duty Delhi DMX-44 which was the 40 foot model also rated for 3 sq. ft. All I can say is that while in the broadcast business I knew several professional riggers that stated that the Delhi towers were way under rated. We used several in point-point VHF/UHF STL applications in some rather demanding locations. My own DMX-44 had a Cushcraft A3 at the top, a six element home brew 6m yagi about three feet above it, and an 11 element 2m yagi about 4 feet above that. Here in Nova Scotia we get all kinds of nor'easters and the driver element of the A3 actually broke before the tower suffered any problems. I retired it a couple years ago when I upgraded to a 64 foot Trylon Titan 500. The Delhi was over 30 years old and had served it's purpose well.
W9GB
« Reply #3 on: July 18, 2014, 08:15:43 PM »
Wade is a well known manufacturer in the Cable Television and Wireless Internet industries.
Delhi Antenna products has been a major supplier and leader in the consumer electronics industry for over 40 years with TV antennas and tower products.
TACO Antennas are designed for both Military and Commercial applications for VHF and UHF frequencies for over 70 years.
Each name has goodwill and value in its own market and we have chosen to keep all three names as part of our organization and marketing.
DELHI TOWERS can be found in the Wade section.
http://www.wadeantenna.com/category.php?c=2&sc=6
Delhi DMX Towers -- Brochure
http://www.wadeantenna.com/ius/resources/DMX.pdf
« Last Edit: July 18, 2014, 08:22:10 PM by W9GB »
VE1IDX
« Reply #4 on: July 19, 2014, 06:51:47 AM »
I suppose I should note that the tower that i was using was the freestanding type and was not bracketed to anything. I forgot about the DMX line of bracketed towers.
