A lot of coin for a SSB only rig
It says it does CW to 0 to 10 Watt.
However it is missing the 160, 80, 60, 30, 17 and 12 meter bands. For some, that could be a deal killer right there.
I like the relatively inexpensive bolt on battery pack, (compared to what the SGC 2020 battery pack cost and that is if you were able to find one).
Right now this is the only 20 watt HF radio on the market. The last 20 watt HF radio was the SGC-2020, it was retired almost 10 years ago. But unlike this, the SGC-2020 covered all the ham bands.
Reliability? That remains to be seen. Would I buy one? Maybe I would. I would like to see an antenna jack and the mic jack on the front panel.
Price:$399 (no battery)
TJ5A fully assembled version, comes with custom made speaker handmic
Assembled version in stock and ready to ship.
custom made 4400mAh lithium battery pack with charger $39
military version radio back, holding TJ5A with battery pack $15
500Hz CW audio filter(kit, soldering job needed) $19
RX:3.500-30.000Mhz (broardband RX is available by adjusting the jump cap)
Tx:7.000-7.3000Mhz, 14.000-14.350Mhz,21.000-21.450Mhz, 28.000-29.700Mhz
High performance AGC
features strong signal handing ability
+/- 120Hz RIT is available
DDS controlled, LCD display,heavy duty metal case
SSB: 0.25-20W,
CW:0.1-10W output adjustable,rx sensitivity 0.2uV10Hz,100Hz,1KhHz,10KHz,100KHz tuning rate available
Dual VFO with 40 memories
Memory transfer to VFO
Crystal IF filter 2.4K
RX:250MA, TX:4A
size:180mm wide x 58mm high x 200mm deep, battery case deep 35mm
weight: 1500g without battery
