eHam Forums => MARS => Topic started by: WD8DBY on April 05, 2021, 10:29:10 AM
Title: April 60 Meter Outreach Interop
Post by: WD8DBY on April 05, 2021, 10:29:10 AM
MARS operators will conduct sixty meter outreach operations with the amateur radio community from 7-10 April on sixty meters channel one, frequency 5,330.5 KHz at 1200 and 2000 hours local time.  Amateur radio operators are encouraged to take advantage of this interop exercise.  Go to www.dodmars.org to take a WWV/H listener survey.  Survey results are shared with WWV/H and NIST to help document the continued need for these stations.
v/r
Paul
Chief, Army MARS
Title: Re: April 60 Meter Outreach Interop
Post by: WD8DBY on April 14, 2021, 06:13:13 AM
Thanks to everyone who participated in this April 60 meter outreach...we will do the outreach again the first week of May.
English
Chief Army MARS
Post by: W8NSI on April 28, 2021, 08:43:20 AM
For the May op...
Are SHARES stations allowed to participate using the 60m shared channels or any of the published MARS freqs? Not all SHARES stations are amateur radio operators.
Post by: WD8DBY on May 01, 2021, 11:35:42 AM
For the May op...
If you are operating as a SHARES station, you are permitted to use the 60 meter channels as the 60 meter channels are primary use for federal stations and secondary use for amateur stations.
v/r
Paul
