eHam Forums => RFI / EMI => Topic started by: K7JQ on December 12, 2022, 02:25:54 PM
Title: RFI to clothes dryer
Post by: K7JQ on December 12, 2022, 02:25:54 PM
A friend of mine is having RFI issues *to* his electric clothes dryer. It's a late model Whirlpool with matching front load washer. Anything over 100W and the machine's digital control panel lights up and beeps. Antennas in an HOA are dipoles close to his roof, about 20 feet from the dryer. Are there ferrite toroids that will fit over the very thick dryer cord, or any other recommendations? Thanks!
Bob K7JQ
Title: Re: RFI to clothes dryer
Post by: KD0REQ on December 12, 2022, 02:46:47 PM
(1) unplug the dryer. open the control panel (usually one screw, tilt it) and make sure the ground connector from the control head to the dryer body was not omitted. add one if it was.  (2) there are half-inch slip-over ferrites out there, nebraska surplus is one source. (3) worst case, dry clothes when the band is dead.
Post by: W9IQ on December 12, 2022, 03:27:27 PM
Bob,
On what band(s)?
Post by: K6BRN on December 12, 2022, 04:41:36 PM
Bob K7JQ
Hi Bob (K7JQ):
Oddly enough I have the same machines (washer + dryer) and have found that they are very susceptible to conducted EMI on the POWER line.  It's worst on 40M.  Adding an ISOBAR filtered power strip solved the problem, one for the washer, one for the dryer.  But this won't work too well on a 240VAC electric dryer (mine is gas heated).
It does suggest that wrapping the power cord through some LARGE mix31 ferrites - or building a 240VAC jumper that has many wraps through one or more large Mix 31 ferrite toroid's may help.
Brian - K6BRN
Post by: K7JQ on December 12, 2022, 06:35:13 PM
Bob,
On what band(s)?
I believe 10 and 15M. I just spoke to him about 20 minutes ago…another friend of his had a large ferrite that he was able to wrap the power cord through twice, and voila, it did the trick! Usually it’s not that simple, but he lucked out. Thanks for the replies, guys!
