eHam Forums => HomeBrew => Topic started by: WT1V on February 05, 2023, 09:14:24 AM
Title: new affordable SA and VNA
Post by: WT1V on February 05, 2023, 09:14:24 AM
I don't know how many hams know about these now affordable testing devices. One is a spectrum analyzer and the other one is a vector network analyzer, both very expensive! Check the TinySA and the NanoVNA on EBay!! Both can be found for around $50!!!!  Not thousands and there are lots of UTube tutorials on how to use these.
Now hams can afford these devices!!
73 wt1v
Title: Re: new affordable SA and VNA
Post by: K1KIM on February 06, 2023, 06:49:26 AM
73 wt1v
The $50 NanoVNA's are not quality units. Supported devices that are well built with metal cases and 4.3" screens will cost around $100-$125. Still inexpensive compared to lab quality equipment. They can do a lot more than just analyze antennas.
Installing NanoSaver software on you PC is also a big plus.
Stay away from the AliExpress "specials"
Post by: AE5X on February 06, 2023, 01:48:42 PM
Here's one application of a tinySA:
https://ae5x.blogspot.com/2023/02/the-utility-of-elecrafts-cp1-bi.html (https://ae5x.blogspot.com/2023/02/the-utility-of-elecrafts-cp1-bi.html)
Post by: KX4OM on February 06, 2023, 03:35:33 PM
Those devices are just fine for amateur work, assuming you get one from a reliable source, and you are not planning on bidding on government contracts.
Check the groups.io forums on tinySA and nanovna-users for advice. I got both from R&L Electronics.
Ted, KX4OM
