eHam Forums => Antennas, Towers and more => Topic started by: KO4NR on March 23, 2023, 11:37:54 AM
The design I have shows a little over 34 feet of wire between the feed point on the ground and the 40-meter trap. I have about 50 feet available for the vertical section so was wondering if the trap needs to be in the horizontal section or can I just move it out into the horizontal section. Would like to use as much height as I have available. Between the 40-meter trap and 80-meter trap the design shows a little over 31 feet of wire.
Bill KO4NR
To retain 40 meter operation the trap only needs to be 34' from the feed point. It can be anywhere you like.
To retain 40-meter operation the trap only needs to be 34' from the feed point. It can be anywhere you like.
Thank you. I have a total of 150 feet of wire and found that I have the space to hang it. The horizontal section will be in dog leg. Didn't want to cut it if I didn't have to. It's a trap Inverted L antenna for 160, 40 and 80 meters.
Bill KO4NR
