Author Topic: Active antenna  (Read 2217 times)
KA4NMA
« on: October 10, 2017, 11:25:39 PM »
Does anybody have an lf/hf active antenna that they are willing to part with?
Randy ka4nma
G4AON
« Reply #1 on: November 12, 2017, 09:34:45 AM »
If you fancy an easy weekend project:
http://www.qsl.net/g4aon/pa0rdt_aa/
Much cheaper than buying a ready made one.
73 Dave
VA3VF
« Reply #2 on: November 13, 2017, 06:36:28 AM »
73 Dave
I'll second that. The Mini-Whip is an interesting antenna. Just install it as per instructions, and ignore the criticisms.
I bought mine on eBay assembled. If you go this route, make sure to get the model with the isolation transformer in the power feed unit.
Not much of an improvement over a random wire above 16MHz, but very good below 16 MHz.
If you want to 'see' one in action, go here:
http://websdr.ewi.utwente.nl:8901/
The antenna was damaged in a storm a couple of weeks ago, but looks like it has been repaired.
ZENKI
« Reply #3 on: November 24, 2017, 08:50:57 PM »
If you want high performance try something like this.
http://bonito.net/ml052/en/index.html
Its easy enough to make one yourself.
If you start with antenna thats too small you will always be hearing the noise floor of the preamp and not get  a good signal to noise ration. Thats essentially the problem with most small active antennas. Bump up the antenna size   you do get a better signal to noise ration with all the benefits of the active designs.
