Author Topic: New to EZNEC - modeling coaxial balun/transformers  (Read 515 times)
N2MG
Administrator
« on: November 14, 2017, 09:35:57 AM »
I'd like to know if EZNEC 6 handles coaxial impedance transformers (like a 4:1 used in a typical folded dipole design) - and if so, an example of it (.EZ file)
Thanks
Mike N2MG
« Reply #1 on: November 16, 2017, 01:11:41 PM »
EZNEC has a transformer model in which you can set one winding to 50 ohms and the other to 200 ohms for a 1:4 impedance transformation.
You can model the balun function by modeling the coax shield as a thick wire and the balun as a load.  Ideally you would measure the choking impedance with a 2 port network analyzer as suggested on the G3TXQ web page.  AFAIK EZNEC can't take a physical model of a balun and calculate the impedance.
« Reply #2 on: November 16, 2017, 02:11:59 PM »
http://www.hamradiodeals.co.uk/forums/viewforum.php?f=46
http://www.arrl.org/files/file/Antenna%20Modeling%20for%20Beginners%20Supplemental%20Files/EZNEC%20Modeling%20Tutorial%20by%20W8WWV.pdf
Plus there is a lot of files and other Eznec stuff out there if you look.
K4SAV
« Reply #3 on: December 02, 2017, 03:56:29 PM »
There is more than one type of 4 to 1 balun.  Models of ideal current mode baluns are very simple in EZNEC.  The transformers built into the software are implementations of ideal transformers.
Unun models are easy because one side of the secondary is connected to the shield on the primary side.  Voltage mode baluns are a little more complicated because the shield side of the primary is usually connected to the center tap on the secondary side.
If you need a more complicated model that can calculate balun loss and common mode currents for a nonideal current mode balun, here is an article by W7EL describing how to do it.
http://eznec.com/misc/ibalun.txt
Jerry, K4SAV
« Last Edit: December 02, 2017, 03:59:42 PM by K4SAV » Logged
