Author Topic: small rf connectors on Japanese radios  (Read 973 times)
WB8PFZ
« on: November 24, 2017, 05:26:20 AM »
What are the small rf connectors called that are used on the Icom and Yaesu radios? I am looking to make some jumper cables.
SA4MDN
« Reply #1 on: November 24, 2017, 10:22:48 AM »
If your talking handhelds then SMA
WB8PFZ
« Reply #2 on: November 24, 2017, 04:04:39 PM »
I am referring to the small connectors that are mounted on the circuit boards. Small diameter coax runs from different boards.
DG1YPG
« Reply #3 on: November 25, 2017, 12:40:10 AM »
I think you are talking about Taiko-Denki TMP - connectors,
look here:
http://www.scsiglobal.com/TaikoDenki/Documents/TMP-K-WorkingStandardWithAssembly.pdf
and here:
https://www.ebay.com/itm/Taiko-Denki-TMP-K01X-A1-RF-Coaxial-Plug-TMP-Connector-Plug-x2/122113883082?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D49476%26meid%3Dc3f20e054f444850a18634b488031597%26pid%3D100005%26rk%3D3%26rkt%3D4%26sd%3D122113894996&_trksid=p2047675.c100005.m2219
- 73 -
WB8PFZ
« Reply #4 on: November 25, 2017, 05:08:30 AM »
That's the ones. Thanks
KI4EU
« Reply #5 on: November 30, 2017, 07:21:56 PM »
If you do make  the jumpers let me know.  I need a couple with connectors on one end only.
Do you have the crimping tool, etc??
WB8PFZ
« Reply #6 on: December 02, 2017, 01:20:32 PM »
I have a few jumpers that came from a parted out Yaesu 736r. I do not have a crimping tool. Mike
